Repeated fuel pump failures
kmcculler
Hi, I've got an old VP AQ131D that keeps burning through fuel pumps at a rate of about one a year. I'll buy a new one and slap it on, everything will work fine until next spring... this has happened several times. I do run the fuel out before setting it up for winter.
The pump will still function when I start it back up but I get this surging at WOT. I've tried hooking an external tank up and priming it during this time and it would run fine.... I let go of the bulb and it goes back to surging.
I've checked the plugs, wires, fuel line, fuel, and filters. Any ideas what could be buring up the fuel pump year after year?
Don S
Re: Repeated fuel pump failures
Stop emptying the fuel system during winterizing. It's not necessary at all, and may be your problem.
krazykatz911
When I worked for Federal Mogul / Carter Fuel Pumps, the two biggest issues we had with pumps burning out was:
1: Debris in the fuel tank (even though you empty it, could be dirt in tank)
2: Low voltage due to high resistance across the connectors, etc. Check voltage drop. The voltage drop measured should be 0.5V DC or less. (You must voltage drop test negative first and then positive)
A voltage drop of more then 0.5V DC will surely cook a pump and cause other driveability problems.
Don S
Guys, he has a 131, it's a mechanical fuel pump, not electric.
kmcculler
Just to update everyone. I think I found the problem. Someone on another forum suggested I try adjusting the float to allow for more fuel in the bowl.
I was skeptical as the fuel pump really seemed to be the issue to be but I thought I might as well give it a shot.... Worked like a charm. I took her out this weekend and I don't think she's ever run better.
Thanks for your help guys.
bruceb58
Jeez...that is what I get for not reading the whole thread. When he said burning up fuel pumps, never thought it could possibly be a mechanical pump.
Don S
I wonder what other information that other forum had that we didn't have. Since having the float level adjusted makes it better than ever, there must have been a problem at the end of last year as well.
kmcculler
No problems I could detect at the end of last year. I was highly skeptical the adjustment would work for me but I thought "hey its free to try it". Glad I did.
I went back and looked at the other post to see if I gave them any additional info.... all I could find was some slightly different wording and this "The surge will go up to about 4500rpms then down to just under 3k and back up. When I open it up it will run fine for about 10/15 seconds before the surging starts up."
