JASinIL2006
- Feb 10, 2012
- 5,724
Hi all, a friend of mine has a 2006 Rinker Captiva 192 Alpha One Gen 2 that he bought nearly new, although when he purchased it, the original engine had been replaced with a 1998 4.3L. (I don't know what happened to the original, but I suspect it was ruined and replaced with an older motor so the boat could be sold for a quick profit.)
Anyway, for years he's been unhappy with the power produced by the 4.3L and he's thinking of swapping motors. I suggested he look at something like a 5.7L. From what I've read here, it sounds likely that the front motor mounts will need to be modified, and I expect he'll need to change the upper part of the outdrive to get a gear ratio more suitable for the V8.
My questions:
1. Other than the engine, front engine mounts, and likely the upper unit on the outdrive, what would need to be changed? I'm assuming he'd get a fully dressed 5.7 from someplace like Michigan Motorz. Exhaust pipes? Coupler? Electrical harness?
2. The big question: how difficult is this swap? I would be willing to do the work with him. I'm no mechanic, but I have pulled the 350 Mag in my boat when I restored it, so I'm a bit familiar with the process. I don't mind doing research and learning new stuff, but I don't want to get into a project that's completely over my head.
Any thoughts on this swap would be welcome, as would links to threads where others have done this. (I tried the search function, but I find that mostly frustrating to use...)
Thanks!
My questions:
Thanks!
