Hello All,
I am a longtime reader first time poster. I have 1989 2755 Bayliner powered with OMC King Cobra 460 cu in. After taking on some water in the engine area, I have found a sizable leak in the "Y" exhaust pipe.
I have searched this forum and learned to replace this item, I have to remove the motor and I think to myself; is this motor/outdrive worth the cost and effort to fix? I have read a lot of negative press for this outdrive and am thinking I should just change the whole setup.
I am not experiencing the speed and response "out of the hole" I would like. If I decide to keep this setup, I would like to fuel inject the motor and have headers installed in hopes to increase the HP.
If you owned this boat, would you rebuild and rekit the fuel system for fuel injection? or would you consider replacing the entire setup?
What motor/outdrive could/would be best to install, run maintain and improve performance?
Thanks,
Kurt
Thanks,
Kurt
