Replace fuel/water separator Merc 4.3L
baylake
Hi,
On the box of the new fuel/water separator, it says need to release pressure from fuel line before remove the old filter. Do I need to worry about it or just remove the old filter out.
2007 Mercruiser 4.3L water cooling
Thanks
Don S
Re: Replace fuel/water separator Merc 4.3L
says need to release from fuel line
Release what from fuel line?
Do you have a Mercruiser serial number handy? Is this an EFI engine?
baylake
Sorry - release pressure from fuel line. Thanks
baylake
Serial Number is xxxxxx. I don't know if it is EFI engine or not. How can I find that?
Don S
You don't have EFI, you have a carburetor. Found that out with the serial number.
Don't worry about fuel line pressure, your fuel filter is on the suction side of the pump, not pressure side.
baylake
Thank you Don.
