JASinIL2006
- Feb 10, 2012
- 5,724
While winterizing my boat yesterday, I found myself struggling (again) to reach the lower block drain on the starboard side of my 350 Mag. It's a plug that is underneath what I think (?) is the knock sensor. It's the only plug that requires a wrench - a 9/16" - to remove, and the older I get, the harder it is to get a wrench down there, loosen the plug and get everything out without dropping something into the bilge.
My question: is it possible to insert some sort of nipple into that threaded opening and use the standard blue plastic plugs instead of the metal plug? Will that have any effect on function of the knock sensor (or whatever that thing down there is)?
Second question: if I can use a nipple that will accept a blue drain plug, what size will I be looking for? Or even better, if there is a part number or link to nipple, I'd be most grateful.
Thanks!
Thanks!
