Replace or not to replace...
Homerr
I found one good stringer (out of 4) in my project. There appears to be no rot, and it seems to still be bonded to the glass.<br /><br />I'm replacing the other stringers, since they were shot.<br /><br />You think I should leave well enough alone or go ahead and replace it too?<br /><br />It is an outside stringer.<br /><br />Thanks,<br /><br />H.
crab bait
Re: Replace or not to replace...
if'n its TRULEY good ..intacted, an glassed in.. it mite be real s o b to remove.. mite do more harm in removeale..<br /><br />also ,, a single stringer left in would be the ticket for keepin'the hull from 'wrackin' while under construction...
Homerr
Kinda what I was thinking Bait...<br /><br />Leave well enough alone. It's in real tight, and I intend to run cross pieces anyway between the stringers (something factory DIDN'T do)<br /><br />Thanks guys,<br /><br />H.
