Replace or
further
thoughts? Got the gasket surface good and flat. One of the inside walls is a bit thin though in a spot.
Grub54891
From my perspective, those don't look flat. Flat would be Shiney all the way around, milled or sanded on a flat surface. Filing don't work that well in my experience. Besides, you have a thin spot so it's just a matter of time before it damages the motor.
Use a flat surface and true up the surface
jerryjerry05
The exit is what you should worry about, stick a piece of wire in there and see if it's blocked and any rust comes out.
You can get the surface milled.
