Replace prop shaft bearing on v drive, 1978 house boat with 318's in it.
chris0061
A friend of mine has this housboat and we were wondering if when we pull the boat and find the bearing bad is it a big job to replace it. Reason for pulling, they bot beached and when they got out there was a vibration on one engine and he thinks maybe he bent a prop there for causing a week bearing to get worse. there is no water coming in the boat or anything like that. I work on io's but never dealt with vdrives before. Thanks in advance.
chris0061
Re: Replace prop shaft bearing on v drive, 1978 house boat with 318's in it.
ok thanks, I'll have to really read up on this.
Ayuh,... I'd sooner think the Prop, or the Prop Shaft is bent...
