jeremy5780
- May 8, 2008
- 147
I rebuilt my 1998 115 crossflow back in 09 ran great! well this season I put a new set of head gaskets on it, and the first trip out the port side gasket leaked water in. It must not have gotten a good seal. So now I got the block torn down and had to have the port bottom cyl bored to 30 over, the other 3 are 20 over. So I have to put a new piston and ring's in the 30 over cyl, but my question is can I reuse the other 3 sets of rings in the block? The motor had maybe 100 to 200 hours on it before I replaced the head gaskets. There where no scratches or dings in the walls they looked perfect. But I went ahead and had the three other cylinders honed while it was at the shop being bored. No obvious damage or wear to the three pistons and rings other than a little carbon build up I will clean off.
