Re: replacement foam
The foam is basically to keep the boat from sinking when it gets flooded. Limited noise dampening, and boyancy.<br /><br />You can use any closed cell styrofoam, and it is basically free. Cut up the hard styrofoam from boxes and packaging companies. You can also buy it cheap from lumber compaynies, Home insulation board. When I replaced the floor of my trihull boat, that is what I did and it worked great. The old foam that I had was waterlogged, weighed a ton. I removed it and replaced it with white styrofoam. The white closed cell styrofoam is almost impossible to water log.<br /><br />I have a 1969 Glastron deckboat that doesn't have any foam. It never did. It floats very well. I am filling the hull with empty antifreeze jugs to supply flotation if it ever springs a leak, but not for normal use. It is not needed.
