Replacement speakers for a 2016 Four Winns H190 SS.
Jimwhall
I have 4 speakers, two in the boat and two firing out the back by the built in chairs. Has anyone replaced speakers in this boat and know the depth/size needed?
briangcc
Nope. But I bet if you pop the trim ring off and pull the screws you can figure out the mounting depth used and what you have available. Also check the ohm rating as it should be stamped on the speaker magnet.
Jimwhall
Turns out after some jimmying they were just jammed on there.
