Replacement Valve Covers - Stay OEM? Cheaper alternatives?
dhardest
I have a 2007 VP 5.0 GXi-G and as I was working on the steering actuator I noticed some rust around the edges of the valve covers. This winter I'm planning to replace the exhaust manifolds and risers, and while I am at it I may replace the valve covers as well. VP wants $125 and $102 for their OEM covers. But with some online searches I am getting the impression that that these covers are a standard size and that there may be some decent alternatives, either after market or other brands that are a cross reference match (such as GM). Can anyone offer any advice on this?
Part numbers for the covers for my engine are:
Starboard: 3856928
Port: 3856927
Thanks,
Dennis
and GM wants $30 a pair for the exact same valve covers. its a frigging small block chevy (your choices are perimeter bolt (1955-1985) or center bolt (1986 and later). go to your local auto parts store
you can get a pair of carbon fiber covers for $70 or polished aluminum ones with cool flame graphics in them for about $70. the stock stamped steel ones are $30
RCSConstruction
Cheap, used freshwater ones can be had on eBay all day.
Once you take the covers off, you'll probably find all you need to do is a little sanding a repainting though. Mine had the same issue
Lou C
reman heads and valve covers painted.jpg Just treat the rust with rust converter and spray em up. Screw Volvo and their parts highway robbery.
dhardest
Thanks for the tips everyone. I found these with a quick search. At first glance they look similar and have similar holes in the covers for the flame arrester, etc. This item description gives dimensions. Before I buy would be good to double=check the dimensions just to make sure they're a match. And then look for Volvo Penta red paint to match the rest of the engine.
https://www.summitracing.com/parts/sum-g3319b/overview/make/chevrolet
Would the same philosophy apply to the gaskets? VP wants $50 each side for the gaskets. This same site offers them for $15.99 a pair and a set of bolts for $9.
Is this for real, or is there something I'm missing? Seems absurd that there's this big a difference in price for basically the same parts.
see post #2.
buy ford red engine paint, not quite a perfect match, however you cant really tell.
get the felpro gaskets
volvo and mercruiser buy the motors from GM. its a truck motor. they buy the parts from GM parts direct too (for slightly less than the same price you and I can buy them for). then they need to have a few buildings with people in them to putt them, inventory the parts, re-package the parts, shelve the parts, market the parts, then ship the parts, etc. that all takes overhead. so both volvo and mercruiser must charge at least 2.4x what a part costs to cover the overhead.
cut-out the middleman and you save about 240%
your question was to stay OEM or not. if you wanted OEM, you should have bought from the GM dealer (about same cost as summit)
dhardest
OK - Thanks so much for the advice. I'll go ahead and buy these items ($65 gets everything - both covers, both gaskets and a set of 8 bolts), and get them painted up and ready to go for this winter when it comes time.
"if you wanted OEM, you should have bought from the GM dealer ...." I guess that's true!
