replacing 1983 140 HP lower unit gears with 1974 115 lower unit gears.
Jeff2012
Replacing 1983 140 HP lower unit gears with 1974 115 lower unit gears from a nice extra lower unit I was given. Can this be done? Or are the gears different or a different ratio.
Thank you.
Daviet
Re: replacing 1983 140 HP lower unit gears with 1974 115 lower unit gears.
I would look at the parts breakdown for each lower unit and see if the part numbers are the same for the parts you want to exchange.
Jeff2012
I don't have any books or #s on the parts. I guess I was looking for an easy answer on weather the parts are interchangable.
Faztbullet
Sorry but will not work as the 74 gears are for hydro mechanical setup and case internals are machined different. The forward gear has notches on it to drive the oil pump in nose of unit.
Jeff2012
Thank you.
Wish I could find someone in the Chicago area to help.
