replacing a 1976 70 hp motor with a 1980 115 evenrude
tphawk09
will throttle cables and stering stuff bolt up to the 115 from my 70?? or do i need to change all the wiring ,throttle cables also ,both thottle levers have trim on the lever,but the 70 dosent have it on the motor thanks
mrcj001
Re: replacing a 1976 70 hp motor with a 1980 115 evenrude
....if the throttle cabes are the same length they should work.
If not, if they are too short or too long, you could have trouble with cable adjustment.
The trim wire just snakes up the remote handle.
tphawk09
great thanks,do u think its 2 much motor for a 17 and half f/g boat???
86 century
Ensign
We need a little more info. Do the plugs match(as far as color) I think there were only two in the those years. What is the boat rated for and what is the condition of the boat are the big questions. Good luck
tphawk09
hi what do u mean by plugs??? the main harness i asume??? the boat is a 1978 surfmaster its in great shape,i cant find any info on but the larson made some of them thanks again for your help,just thinking of this as i can get a deal on a 115 for 800,instead of sinking money into the 70 i have i checked compression its 110 54 104 on the 70 ,it idels awsome but dies under load ,u think istsa piston or headgasket??? thanks again
86 century
Ensign
You assume correct the big one under the cover. There should be an info plate some were in the boat. That give max hp and load. About the compression I would pull the head and have a look. With one that low the problem should be fairly obvious and if not you can rule out the head gasket they are cheep and you can get them from Iboats in a day or two. If you are unsure post some detailed pics. Good luck
