An aft chrome 6? mooring cleat on my fiberglass pontoon boat (13? 2004 Escape Cruz - see photo below) completely snapped off during recent extremely strong high winds on the lake. All that?s left are the 4 chrome screws and a little bit of metal underneath each screw head. I haven?t yet attempted to unscrew these remnants from the fiberglass.
Here?s my problem. The Escape Cruz is a 100% enclosed/sealed fiberglass pontoon deck boat, with absolutely no underneath access to where this mooring cleat was located on the aft area. I can easily buy a replacement cleat but attaching it presents some obvious questions and problem. I assume possibly the boat manufacturer attached/screwed down all the cleats and chrome railings before the topside was permanently sealed onto the fiberglass dual pontoon hull, probably using backing plates and lock nuts underneath the fiberglass to firmly hold all the screws. However, I?m not sure that such was the way original installation was accomplished during boat manufacture. Maybe there was an easier way used.
Once I remove the remnant screws, I am concerned that any locking nuts and/or backing plate will simply fall down into the hull. Ugh. Then, what??? A few questions:
1) Has anyone encountered a similar inaccessibility problem and know a way to deal with it?
2) Does anyone know if typically on such boats a backing plate is firmly seated and already has threaded screw holes, so that all I?d have to do is unscrew the old screws and screw in new ones?
3) Google searching made me aware of marine ?well nuts?, to install something in the blind. However, these apparently don?t use backing plates for strength of hold. Has anyone used ?well nuts? to install something such as mooring cleats on a boat? If so, would they be strong enough to securely hold/moor the boat line to my dock and the cleat not be torn out from the boat during winds up to perhaps 30 to 40 MPH?
4) Any other suggestions?
