thomas.carona
- Nov 11, 2011
- 3
Hi all. My first time posting here so if I make a mistake my apologies up front. My Bayliner 28ft Contessa has base rail fittings that I want to replace with stainless steel fittings (for a nicer look and to give it more corrosion resistance). The problem I can foresee is once I remove the old fittings I can't get at the bolts from the fittings to backing plate with each new fitting from the underside. I want to try to use the original screw holes for the new fittings but I also want to ensure they are installed so they won't pull out so easily. Any practical ideas will greatly be appreciated. Thanks.
