I'm replacing a bilge pump that came with the boat and the original wiring is strange. My new pump has 2 positives to trigger the pump, one is auto mode and the other is manual. The pump I'm replacing is strange, it has 3 wires coming from the console switch, 2 grounds and 1 positive. The positive is constant, with the dash switch OFF the two negatives are "live", with dash switch set to ON (manual override) one of the negatives is switched off and this triggers manual override of the pump. This is so weird.
So, I need to reverse the manual override so it's a positive not negative trigger for the new pump. I thought maybe I could move the connectors at the back of the dash switch but it looks a bit messy there and with the fuse right there not sure how that would be affected.
I'm thinking of using a relay to trigger the manual override of the new pump.
30: + fused source
86: + fused source
85: - trigger from dash switch (reversed, when switch is ON power is removed and 87a becomes energized)
87a: + to bilge
Anything off with my logic here? I've done + and - triggers of a relay before but not a reversed negative like I need here.
30: + fused source
86: + fused source
87a: + to bilge
