Replacing check valve in 85 hp Force engine
Upnorth1963
I'm trying to replace the check values in my Force fuel pump. I've successufully removed 2 of the valves. The remaining valve is giving me problems. I can't get it out of the fuel pump body. I've tried using "steel picks" similar to those used by dentists. It won't budge. Does anyone have suggestions on how to pop this valve loose. Thanks in advance.
jkoppe73
Re: Replacing check valve in 85 hp Force engine
I removed mine by carefully taking a dremel tool and grinding two grooves opposite of each other in the valve, then take a large screwdriver insert in in the groves, twist, and it will pop right out.
WaveJumpingMaxum
2nd stage valve is removed by prying it out using a hook shaped tool. Firsts stage valve u put a hammer and pin in the in the pump body behing the valve and tap it with a hammer the center valve in the middle is held with 2screws. remove the screws and it falls right out. and if im not mistaken every one you take out needs a new valve and new gasket i dont think they can be reused.
