Replacing Discontinued Thru-Hull Trim Wiring
MercMonster
My wiring harness for my trim limit switch and trim position sender have been "discontinued" and need to be replaced due to corrosion and I am looking to find a suitable replacement. The wire looks like a standard A/C electrical type wire. Double-connected wires to each switch. What type of wire can I use as a substitute for this part of the wiring, hopefully one that won't corrode for quite some time? And as far as sealing where the wires go thru the hull, am I going to need some type of sealant in that area or is the black rubber seal going to do the job with the new wiring?
