speed_demon
- Mar 20, 2012
- 111
When I replace the driveshaft (pinion, not prop shaft) in my lower unit do I need to reshim the shaft or can I just put it back together with the existing shims? It has about 500 hours and should be in great shape internally. I have to replace because of oil pump spline damage on the powerhead side. I don't plan on replacing any bearings or gears. Can you usually get away with just replacing the shaft with the existing shims? If not how do you go about shimming it? My manual is somewhat lacking in explaning it.
