Replacing engine
Ezel
I have a 2000 trophy w/a with a 4.3 mercruiser 190 hp alpha 1 do I need to remove the out drive to remove the engine? I'm going to do work on the out drive as well but does it Need to come out before is what I was questioning. Thanks to all
Alumarine
Yes it does. Make sure the shifter is in forward gear before removing or installing the outdrive.
greno
Welcome to the forum!
Yes, the outdrive has to come off. It's simple. Put it in forward gear. Remove the trim rams from the upper case. Remove the six nuts between the bellhousing and the upper caseand pull the outdrive out from the bellhousing. Now you can pull the engine.
achris
More fish than mountain goat
I've done a video on it... Takes 3 minutes. Click the "My Videos" link at the bottom of this post...
Chris........
for those that never pulled a drive before, it may take a half an hour by the time you gather the tools, etc.
AShipShow
Yep, and don't forget to remove the speedometer tube (don't ask how I know).
