Re: Replacing Exhaust boot 1988 3.0L AlphaOne
Brit-Man<br />You do not need to remove the bell housing to replace the boot. You have to have the bell housing installed to install the boot.<br /><br />Check Merstuff.com, they have a write up or this and also removing the drive. Remember to place the throttle lever in FULL forward when you remove/install the drive.<br /><br />You do need to get the bellow expander tool, it will help. Alternatively, you can make a tool consisting on a 1 3/4 inch semi circular disc and a 1/4x1/4x 12 inch long square rod. Weld the rod perpendicular to the disc at the centre of the straight edge of the semi-circle. Use this tool through the bell housing to lever the boot open to get it over the bell housing. The mercruiser tool requires the shift shaft to be removed to use it, I split my tool and used only 1 side to avoid removing the shift shaft.<br /><br />While you are at this, do the following:<br />1. Check, better still change the drive bellow<br />2. Grease the u-joints (note the correct grease)<br />3. Check the engine alignment<br />4. Insp the shift-shaft seal, it it leaks the shift cable will be damaged.<br />5. Insp the shift cable bellow.<br /><br />Good luck and get help, the drive is heavy.
