OK,
I have decided that I am going to replace my boat floor since it is water soaked and rotted. I was going to buy a boat frame and put my motor on it, however I am not finding any I like or a good price.
So far I have removed a 1 Sq. ft section of my floor back by the bilge bay, and there is about 5" deep of water in the boat. There is a large what looks like foam peice which is going to need to come out. From what I can see I have tapped on, and picked at the stringer, and it looks to be in good shape and is not soft like the floor, it just feels like a solid peice of wood that is wet.
My boat is a 16ft fiberglass boat.
Here are my questions before i start this project.
#1- I am going to be cutting my floor up with a circular saw set to about 1/2" cutting depth. Before I do this I do not want to cut any existing stringers. My boat is the same design as a glastron gt160. Is there just 1 stringer that runs from the front to the back, or will there be several, and some that go from side to side I need to be careful not to cut?
#2- If I remove the floor and the stringers are bad, what wood do I use to make new ones? do I just use 2x4 wood and fiberglass them to the boat?
#3- Is there a certain design I need to follow that can improve the strength of my boat to give it more strength?
#4- When I am adding the floor back in, is there a certain type of wood to use for the floor? Can I just use regular plywood and use that oil, or desk stain to protect it, or does it need to be exterior grade plywood?
Thanks all, I am excited yet worried about starting this project. It is either give it a go, or give the boat frame to the dump, I really wanna see her float again.
