Replacing fuse block...again.
ascus4
Hi folks,
The fuse block behind the instrument has coroded again.
Is there a preferred fuseblock, maybe with a cover or some other design, that you all like to aviod this issue?
Thanks,
Silvertip
Re: Replacing fuse block...again.
It would be helpful if you explained what style of fuse panel you used last, what type of boat this is going into and whether you run in fresh or salt water.
