Replacing gauges
dj0443
I am trying to replace gauges from a 2013 nitro donor boat to a 2004 ranger. When I hook up the fuel gauge and turn on key, I get 10 volts on ground wire. Also happening when I try to hook up tach. HELP. Thank you
dj0443
Thought I found the ground issue. But it is draining battery. Unhooked wiring harness to gauges and checked the voltage . 9.8 volts. The motor harness is disconnected. There is nothing else that I can come up with that is draining my battery
was one engine a 2-stroke and one a 4-stroke?
two different key wirings, two different methods of kill switch
