replacing impeller on 125 force
125 force 1987 , do I lubricate the housing once I replace with new impeller and do I regrease the splines on the drive shaft before reinstalling. Or anything else I should do. I need the impeller and gaskets but am finding it hard to locate even on this website they only had thermostat. Does that also have to be replaced.
roscoe
Re: replacing impeller on 125 force
The driveshaft splines should be greased.<br />The end of the driveshaft should not be greased, or the shaft will not fully seat.<br /><br />"do I lubrucate the housing"<br /><br />The waterpump housing? You can lubricate it with dishsoap or a little grease to help with getting the impeller in. But I find this to be messy, and then its hard to work with greasey hands.<br />The waterpump is lubricated with water when in use.<br /><br />You can get the parts from any Mercury dealer.<br />impeller part # 47-803630T<br />a complete waterpump kit is #FK1069<br />gasket is #27-F523031<br /><br />Yes, a good idea to replace thermostat every few years.<br />thermostat gasket #27-828319<br />thermostat # F528068<br />thermostat grommet #25-F84504<br /><br />Aftermarket parts are available (NAPA)<br />thermostat # 18-3559<br />fuel pump rebuild kit # 18-7806
imported_bjs
most force and mercury take the same impeller.make sure you turn the shaft clockwise when installing the impeller.dont turn the shaft the wrong direction.they are easy to install.buy a manual its a good tool to have.because your going to need one.
