Re: replacing motor
Well, the first consideration is what the manufacturer rated the boat for. Many 18 CCs are rated for 150hp.
My experience has been that most boats will perform at about 90% of top speed (with rated power) using 70% of rated power. Example: My Boston Whaler Sakonnet 16 would reach 39mph with a 70hp Evinrude and 43mph with the top rated 100hp Evinrude.
The 70 burned about 50% of the fuel that the 100 used. Much of that difference was engine design, but the lighter weight was also a major contributor.
So, if your boat is actually rated for 150hp you can get satisfactory performance, improved handling, agility and fuel efficiency at the sacrifice of a few mph in top speed using a 115 carbed 2 stroke.
If that 115 is an EFI 4 stroke, DFI 2 stroke or an ETEC the fuel savings will be much greater but because of the weight the loss of top speed would be slightly greater.
Good luck.
