Ok sounds good to me and what would be a battery life for my kind of boat and I would like to make sure the battery stays charged after every use, what is your suggestion.any marine 24 series battery will work fine. I like the cheapest (think Autozone). Why do you need a battery charger in a 17 footer? Normally they don't have any electronics that run 24X7.
I just looked into those batteries and there are several different ones to choose from, so which one will be the best and last longer.I always thought DieHard marines were the best....until I tried my first AGM (glass mat). If you do the math ($/year), they come out on top all the time. But regardless of cost, they simply stand up better and won't let you down. You won't need a charger. Just buy a $3 multimeter from Harbor Freight and check it before you go out. My AGMs can sit for weeks and not lose and voltage.
If you want cheep, buy a Wally battery that lasts a couple of years. Then check the $/year and you'll be surprised how expensive they really are.
I think the best batteries for Marine applications are Glass mat, like the Optima series http://www.optimabatteries.com/home.php They are completely sealed (good for smaller boats that get bumped around a good bit), last a lot longer and are less affected by cycling. I got mine on Amazon.com for about $150 each (vs $200 list). Do a quick search on net for optima batteries and review some of the tests.
EVERY boat or car I bought brand new has had a battery that lasted at least 6 years with no problems. The 2002 Chaparral 186 SSI is still the original one and cranks the cold carburator & dry carburator fine.
So for anyone to pick a replacement battery as good as Original Equipment Manufacturer ????
NEVER EVER happen. I have NEVER had ANY replacement battery last 4 to 6 years. Most of my friends agree.
They are all recycled lead. Some not good for 6 months.
Are you guys kidding? You think it's a good investment for him to put a $200+ battery in a $1500 boat? Come on.... :facepalm:
Why do small outboard motors & small riding mowers EAT any battery ?
Because they USUALLY have NO voltage regulator.............They overcharge the life out of them in less than 2 years.
NO battery will take that treatment.
I adjusted & installed a relay to limit the maximum battery voltage in my Everrude 9.9 with electric start.
Companies DELIBERTLY screw people out of their money.
The guy asked what the best battery was... He didn't ask about investment advice or to have his boat appraised.
