Replacing my speedometer pickup what sealant to use
Rupp
Guys,
I'm replacing my boats speedometer pickup and I'm wondering what sealant I should use as the old one looks like it was put on with clear silicon. Is that what I should use?
jbcurt00
Aluminum or fiberglass boat? No silicone on aluminum unless marked as aluminum safe
airshot
I would never use silicone period, below waterline is even worse. Many better sealants on the market.
Rupp
It's a fiberglass boat and I'm looking for better sealant recommendations. The silicone was applied at the factory and has worked for 24 years but I'm open to whatever is better.
nola mike
3m 4200 or PL Marine adhesive
Chris1956
Gee, any sealant that is suitable for below the waterline is fine. I used silicone for 50 years. Pure silicone is completely waterproof.
Silicone is also fine for aluminum. Silicone is often used to caulk windows to siding trim made of aluminum.
Life Seal is good for wet surfaces. If you cannot dry it out, and you need to seal it, Life Seal is the way to go. Water helps with it's curing process.
jbcurt00
Never heard of such a thing.
Please elaborate…
Most silicone has acetic acid in it to speed/help it's cure.
Acetic acid etches aluminum
EDITTED TO CORRECT CHEMICAL: Acetic not acetate.
dingbat
Acetate etches aluminum
Are you sure you’re not mixing “chemicals up?
According to all the material comparability charts that I found, acetate has excellent compatibility with aluminum
A goggle search for “Acetate etching aluminum” turns up nothing as well
jbcurt00
Editted my mistake:
It's acetic acid in some silicone:
Acetic acid in silicone etches the aluminum and leads to corrosion
