Replacing Old Steering cable
miichael18
When i go to replace my stuck steering cable can i just measure my old one and order one the same length as it?
roscoe
Re: Replacing Old Steering cable
Sure, if the old one was the correct length.
whblaylock
I just replaced one on a 24' Fisher pontoon and I found that the best way to get the right cable is to get the number off of the cable. If it is a teleflex and most likely it is, the number is molded into the cable but it might be hard to find. I had to read mine with a magnifying glass. The number told the dealer exactly what I needed as far as length and design. I then shopped that number around on the internet as well as local dealers and I found a dealer who ordered it, had it dropped shipped to me and charged me $50 less than I could find it anywhere. Also, you will see steering cable kits that include the helm and if you don't need that you will save $.
ivar
And when you remove your old cable , tie a rope or someting to it , way easier to get the new one in place. Forgot that once and spent almost 2 full days getting the new one in place. Can you say #¤%&¤#%&%¤#&?
miichael18
will this steering system work with a 1989 125 HP force engine? it says...<br /><br />Twin-cable systems recommended for boats that exceed 50 mph or experience instability due to engine flutter.<br /><br /> http://www.iboats.com/mall/index.cg...eering&**********=864182065&*******=864374451 <br /><br />does this kit include everything but the steering wheel?<br /><br />it says $108.87 - The Rack Cable, 16' is it the kit or the cable?<br /><br />or should i get this system?<br /><br /> http://www.iboats.com/mall/index.cg...eering&**********=864182065&*******=864374451
