Replacing OMC 3.0 140hp with a Jeep 2.5L
newportfrog
Does anyone know if this can work? Someone told me I could use a Jeep 2.5L to replace my OMC 3.0 that has a cracked block and manifold.
McKenzie
Re: Replacing OMC 3.0 140hp with a Jeep 2.5L
It will work if you can get the coupler and bellhousing! Which i doubt were ever manufactured for that engine.
newportfrog
Any suggestions for a place to get a good deal on a new/remanufactured 3.0 OMC?
McKenzie
the engine doesnt have to be OMC. you can buy a 3.0 automotive long block engine and just transfer all the parts on to it. Besides the obvious, you probably just have to switch the cam and replace the freeze plugs with marine ones.
cobra 3.0
From what car can you find a 3.0 long block? I have an OMC 3.0 as well (built by GM). I've never heard of a 3.0 4 cylinder in a car...a 2.5 yes...off an Oldsmobile Omega early 1980's vintage.
newportfrog
That's why I want to know if a Jeep 2.5 could work. :)
denniz
I dont think youll get a 2.5 to work, what state are you in? Im in Texas and have 2 3.0s at my shop.
newportfrog
I am in Vermont but I am not opposed to travelling to get a decent deal/motor. What are you asking for one?
boat doc
you will need stainless steel head gaskets as well, unless you are closed cooling. Another thing to think about is making sure you heads, block, intake, are of similar metals. You want it all steel, or aluminum, again unless you have closed cooling
denniz
npfrog im sure its not worth the trip. $800. complete for used. Try looking in your area.boat doc... WHAT ? are you thinking he can use this 2.5? How would he bolt it up?
newportfrog
I will throw it out there that I want to buy one but I won't rule the trip to TX out just yet, maybe I can pick up some cars at the same time.
boat doc
No I do not think he can use a jeep engine, I was adding to McKenzie's comment<br /><br />If he gets an auto block on a fresh water cooling system (long block) He will need to use stainless steel head gaskets as well as brass freeze plugs.<br /><br />another thing, a lot of engine marinizers double spring there vavles due to boats running higher revs.
jddeiler
i believe the 3.0 is a bored out 2.5
