Replacing OMC Pressure Tank Fittings - 1950's 7.5 Evinrude Fleetwin
andy7918
I have a OMC pressure tank that leaks fuel from the fittings. Does anyone know a replacement quick connect make or brand that will work on the 3/16" fuel lines that I am running? It seems like everything online is for 3/8" lines... I have already replaced the o rings..
nwcove
Would the above work on a 2 hose pressure tank ????
????......why wouldnt any of those options work? ya just need two of what ever quick connect. i ran one of my cd 14's for a whole summer with air line quick connects with the pressure tank
bilge rat jim
You can buy the original design hose-end fitting from Mastertech Marine. You probably should be seated when you see the price. (At least it won't end up looking like a frankenstein fuel line :lol:)
Never had a problem stopping leaks with factory replacement o-rings.
andy7918
I am pretty sure I damaged the housing or something on the stick female fitting when I was replacing the orings the first time. Specifically getting the rotten old ones out. Got impatient and used a pair of needle nose. anyways I just used a in line brass barbed male fitting from the home depot plumbing section to skip the pressure fitting for now. NWCove, I liked those ones you showed on e-bay, I will probably give them a try.
