Hello all,<br /><br />Great forum and glad to be a part of it. For this first post, I'm looking for some advice. <br />1993 4.3 OMC w/Cobra drive.<br /><br />Found milky oil on the drive so it's time to replace the seals. Also, the gear oil is slowly leaking from what looks like the prop area, so I'm assuming a shaft seal is where the water is coming in and the oil is coming out. But I'm going to replace all of them when I pull it off.<br /><br />I havent done this before, so here are some questions:<br />I have the Clymers manual, however they are not specific when it comes to replacing seals/gaskets in the drive. Is there a standard list of the select few that I should replace when I do this? <br /><br />Also, is there a place anyone would recommend to purchse the seal / gasket kits for both the upper and lower units?<br /><br />Thanks in advance.
