Replacing Power Steering Pump 3.0 Mercrusier
Crappie Jalopy
I need to replace mine. Doesn't look that complicated.
$650.00 and up, for a pump located through a marine parts store. A local boat shop wants $1,200.00, parts and labor.
Saw a youtuber bought a pump at a car parts store, $65.00 +/-. He did the install and It worked. His theory is, if it lasts a couple years, it's worth it.
Looking for anyone that has done this work.
Thanks
alldodge
Its a standard Saginaw power steering pump. Only difference is the valve that screws into the back which the HP line connects to. Can buy just the pump or pump with tank as an assembly. Just remove the new valve and replace it with your old one
Pump rebuild kit is $11-14
New pump is under $50
