Replacing Pump Impeller
mattdd
as far as once a year maintenance...do you replace just the impeller, or the whole housing, gasket, impeller setup? if just the impeller, how often do you replace everything?
AGENT 37
Re: Replacing Pump Impeller
Impeller and gasket should be annual, the housing when it corrosion or damage dictate.
Brandyn
