Rogerdog23
- May 21, 2013
- 52
Looked in the archives and haven't seen this covered for my engine...so hopefully this isn't a repeat.
Motor serial number: 0L012308
I started hearing a squeaking noise last season and finally pinpointed it to the raw water pump. I was able to do so by spraying WD-40 behind the pulley on the pump and the noise would go away for a minute or so. I've also run the engine for 5+ seasons and haven't replaced the impeller so figured I'm way overdue after reading a number of posts here (and it sounds like that can cause squeaking as well).
My questions are as follows:
1. Is there a link somewhere to the steps on how to replace the impeller and I'm guessing the two ball bearings the shaft sits on (to get rid of the squeak)?
2. What is the level of difficulty for this job? I'm pretty handy but haven't done this before.
3. Any thoughts on a parts list? Impeller rebuild kit, the bearings (2), and what else? (could do everything other than the shaft and metal housing). Sierra okay or go with OEM?
Appreciate any thoughts!
