Replacing rear engine mounts Alpha 1
Roman S
350 motor, Alpha 1 outdrive. What is the procedure to replace the rear engine mounts? How do you get the old mounts out of the bell Housing and replace with new? Thanks Roman
Alpheus
Re: Replacing rear engine mounts Alpha 1
Remove the engine.
Remove bellhousing.
press out old mounts.
Install new ones...
Roman S
The engine is out, the bell housing off. Is there a way to press these out in my garage. Thanks again Roman
Ayuh,... I guess that depends on how equiped your garage is.....
A couple right sized sockets, 'n a length of readi-rod could work...
I think BD once posted pictures of a screw-press he built to do it in the field...
I'm sure it can be done on a well equiped hyd. press....
Bt Doctur
pm me your number if you need more info
wca_tim
I put mine in with a heavy duty u-jount press while it was hanging still hanging on an engine hoist.
Alpheus
Thats a good idea. I used a press at work for mine, but that would have totally worked. I have one of those in my garage and didn't even think about that. I will remember that for next time...
