DSBATCHELDER
- Jun 22, 2014
- 4
I have a 2006 mercruiser 3.0 alpha 1 gen 2. I removed the slave solenoid. I am finding it almost impossible to hold the nuts behind the plate so I can get the bolts started. Any suggestions on a tool to use. Will a very thin open ended wrench work? Also, I had to remove the spark plug wire right next to the solenoid and the one closest to the rear of the engine compartment. I may have mixed up the the wires. Is there a diagram that tells me where each plug connects to the dust cap? Thanks for any advice.
