When I bought my boat (tracker pro team 175), used, from a local marine dealer the trolling motor did not work, so they agrre to replace it with another used one they had about. The original was a 36 lbs thrust, the "new" one is a 50 lbs thrust. The wiring has not yet been upgraded between the battery and the motor... it is still the #10 30 amp wire and looks to not even be tinned marine wire or even high strand count wire (mtw etc)...it actually looks like run of the mill THHN wire. I am having heat problems on days when I have to use the trolling motor alot, not to mention that the increased resistance on the under sized wire is probably killing my battery life. Knowing that my 50 lbs 12 volt trolling motor draws about 50 amps at full throttle (motor thrust/system voltage x 12=amperage), I was going to use 60 amp #6 MTW cable and solve the copper corrosion problem with Pentrox brand anti-oxidant/dielectric compound. Anyone see a problem? Any suggestions on other types of wire? I would like to avoid paying the local marine dealer the insane prices they are charging for the "tinned type 3 #6 marine wire" ($42 for 25')
