replacing spark plug wires (ASAP)
leafs
i have a 1974 70hp johnson<br />2 of the 3 spark plug wires came out of the ignition coils.can just the plug wires be replaced or does the coils have to be replaced also. because the wires do go inside of the coils. if just the wires can be replaced,how do i do this.
ad4par1
Re: replacing spark plug wires (ASAP)
Sorry leafs, but according to my manual, these are one-piece units...good luck! (under the flywheel)
leafs
thank you,thats what my manual says to i was hoping there was some to repair them
leafs
I WAS TOLD BY A BOAT MECH JUST TO PUSH THEM BACK IN .DOES SOMEONE KNOW IF THIS WILL WORK.
dmessy
Give it a whirl, trim off about 1/4" off the wire and glue it in with RTV silicone. What do you got to lose? If it works great, if not, back to ground zero and buy new coil/wire setups.<br />I've seen some backyard engineering that has worked for a Looong time...
