lakelover
- Mar 26, 2003
- 4,386
I want to replace one of the tiller washers (#26 in the diagram) on my Merc 20 because the original was made of plastic and broke and fell out. Because of this, there is play in the tiller arm and it doesn't stay in the up position when I pivot it up.
I'm thinking that I might be able to do it without removing the whole tiller assembly as is shown in the manual. Would I be able to get the tiller tube out of the arm, unhook the shift cables and stop switch, remove the arm and do it that way? How do the rubber throttle handle grip and throttle handle (#17, 18) come off? Is it even possible to do it this way?
Or is it better to unhook the cables at the power head and pull the whole assembly off to slip the new washer on?
