Fisrt of all this site is the best I've found. I've been thru thread after thread learning all that I can. Just started pulling the floor from a 72 Clipper. I am going to replace the transom and stringers
. I removed the rub rail and removed all the rivets holding the top form to the hull. I needed to pull the top to get to the transom. Few questions,
1. I still have the boat on the trailer. She sits pretty "square" on it. Will this be a good base to hold her shape while glassing in?
2. Should I place the top form back on after replacing the transom before replacing the stringers and floor?
3. Last put not least, do I need to seal the 2 halfs together around the rub rail when I finish?
Thanks in advance
Thanks in advance
