Hello,<br />I have noticed alot of problems with tilt/trim on this site. My search of the site didn't produce an answer to my issue. Mine seems like one of the simpler problems.<br /><br />Using my trusty Cylmer manual, I have determined that the switch(s) are not functioning in my shifter arm/throttle. (I cut the 3 wires going into the arm and by touching 2 of the 3 wires, I can make my outdrive go either up or down). It could also be a wiring problem/failure in the arm as well, but I can't seem to figure out how to get the arm off and get access to the trim/tilt switches. <br /><br />Is this switch replaceable or do I have to replace the whole arm assembly?<br /><br />I have a 1991 Crownline 182BR with a 4.3L OMC outdrive. The Cylmer manual has a great wiring diagram but very generic reference for the shifter and trim/tilt switches, and mentions nothing about how to remove the shifter arm to get access to the switches.<br /><br />I'm guessing this is relatively simple, but there's not much room to work behind the arm and I can't seem to figure out where to start.<br /><br />Any guidance you could provide would be great.<br />Thanks.
