Fishermark
- Oct 19, 2003
- 5,617
I just bought a new project boat. 1985 Wellcraft 19' with a 3 liter 140hp and Alpha drive. I want to replace the u-joints. I have read through the manual, but have a few questions.
In order to pull the driveshaft out of the upper, I simply remove the large retaining nut and pull out the assembly. Is that correct? I know I need to pay attention to the shims, etc. The question I have is this - as long as I do not mess with the gear and bearings, I can simply reinstall the assembly with the new u-joints and, making sure the shims are in the same place, then torque the retainer nut back down to 200 ft lbs. (I have the chart for converting the actual reading to the length of the torque wrench).
No other tricks or settings to worry about, right?
