Reply from Seafoam
rickdb1boat
After some discussion here, I sent Seafoam an Email to try to find out why their product would make a good stablizer. Here is their reply:
Have you been to our web sight at www.seafoamsales.com? More information there!
There are at least two ways fuels are stabilized. The most common method is to seal the fuel from the air, so that volatility of the fuel deteriorates slower than without being sealed from the air.
There are several products on the market that do this, however when the fuel/air seal is broken, it does not re-seal, and rapid deterioration occurs. Like when you tow the unit around, move the gas cans or when the elements rock a unit that is sitting, unused.
Fuel manufacturers will tell you that their fuels begin to deteriorate about 30 days after it is formulated. Remember most fuels come through a pipeline to consumers quickly and are consumed, there are times when you are paying high prices for fuel that has already begun to deteriorate because it has been in the system.
Sea Foam patented formula is quite unique in its method of fuel stabilization, but we are not the only product that uses a similar method. Those products use various chemical components, where Sea Foam is oil, which we believe to be safer for a fuel system and its component parts, plus Sea Foam is multi use!
Sea Foam is a combination of 3 separate refined oil products, mixed specifically to do cleaning of fuel and oil residue (including carbon cleaning), moisture drying, add lubricity, and stabilize fuel (any brand, grade, including ethanol and diesel).
Sea Foam adds volatility to fuel, and slows down the deterioration process, while still drying moisture, lubricating, and cleaning.
At one ounce per gallon of fuel (diesel or gasoline), or 2 ounces per gallon of fuel/oil mixture, Sea Foam keeps fuel from falling into the non volatile range for up to 2 years when used as above. More is not necessarily better, but as a fuel injector cleaner, professional technicians using specialized equipment use Sea Foam at a gas/Sea Foam ratio of 1 to 1 (50% gas, 50% Sea Foam).
Sea Foam has had reports of much longer successes from consumers. Fuels should be thoughtfully (using careful thought processes) stored in a sealed container or fuel system, in conditions that will not cause rapid decreases in volatility or excessive moisture contamination, such as out of direct sunlight.
Sea Foam also highly recommends that when Sea Foam is applied to a fuel system, that that system (engine) be run long enough to allow the entire system to be purged with the Sea Foam/fuel mixture, to make sure the entire system is protected. Sea Foam will not migrate up a fuel system, the fuel has to move!
Sea Foam Motor treatment # SF-16 (16 ounce container) is also available in One Gallon containers as # SF-128, and 55 gallon drums as # SF-55 for fleets and large consumers. Availability in certain markets is limited on one gallon cans because Sea Foam just began marketing this container in early 2006.
Sea Foam is also available in a SPRAY (same product as Sea Foam, just in a spray) for cleaning, lubricating, penetrating, anything you can do with Sea Foam,and FOGGING. It is sold by the name Sea Foam DEEP CREEP # DC-14, and is available through most suppliers that handle Sea Foam Products. Talk about a really neat product, wait till you try it!
And don't forget Sea Foam BUGS B GONE, 100% water based SOAP for cleaning organic residue such as bugs, molds, mildew, THE SCUMMY LINE ON YOUR BOAT, without surface damage! (and lots more!)
Thank you for your question, hope this helps.
**** Davis
Customer service
Bob_VT
Re: Reply from Seafoam
Rick, thanks for passing that on!
Chunder06
Well that's one way to get free advertising or is it cash for comments, we call it sprooking in Oz,
Texasmark
Read and head Chunder. After blowing it off when I first arrived on this site, I decided to use some.
So I did and.......
I have restored several old engines which I had given up for dead (needing an overhaul) including weed eaters, chain saws, push 4 cycle lawnmowers, old hay truck, and even my 40+ year old diesel tractors..................all in addition to making my outboard run like a top.
And they did say that they weren't the only people who stabilized fuel.....but since it was made for 2 cycle outboards in the first place (OMC) , why not use it? Guaranteed to work or money back written right on the can. Haven't seen the others do that.
8)
Mark
Chunder06
Mark I am not knocking the product....just the sprooking.
rickdb1boat
Well, he did answer my Email promptly (Next morning), so I can accept a little product pushing. I was surprised to get a reply so quick. That's more than I can say for some other companies products that I have inquired about in the past. It was only the BUGS B GONE stuff that I didn't know about and who knows, maybe it works too...
Chunder06
There you go again Rick sprooking their other products, do you have shares in the company.
Texasmark
Hey Chunder, I have thought about invoicing them for all my effort. 8)
Naw. Just like anything else. If it works for you and you are a good natured person, you want others to get lift too. Besides, if they accept your recommendation, it makes you feel like you made the right decision besides the good feeling of helping others.
That's all he's doing, and I too thought about using their other products. But invoicing still is a thought. o:)
Mark
rickdb1boat
I don't care if you use it or not. I'm just passing on info that I obtained for my own benefit and hopefully for the benefit of those on this forum. I'm not "sprooking" anything, whatever the he** that means. I guess that's the expression you use for promoting a product that doesn't work. Questions were asked in another thread and I figured the best way to get them answered is to go to the source. Good enough?? And BTW, it does work for me and I would be happy to suggest others use it where applicable...
Chunder06
Sprooking is when you have a financial intrest in a product that you are disussing and fail to advertise this fact.
rickdb1boat
Sorry. No vested interest in the product.............
Texasmark
So I go to town today; being retired and living in the country it is a selfom event.
Went to Auto Zone, found one can, whent to NAPA and bought 4, went to WW and there were none.
Do I like the stuff? Naw. Just look at the $1000's of $$$ it has saved me, and all the work, on all my stuff I have used in on, especially on my vintage farm tractors.
So blow it off if you want. Loss is your's.......now let's see, where are those blank invoices. d:)
Mark
Plainsman
My Service Engine soon light was on. After 1 can in the tank, the light went off and has stayed off. I'm a believer.
Triton II
Chunder, I haven't seen this stuff in Aus... have you?
Chunder06
No triton, AQIS won't let it in due to the high levels of carcinogens in the unburnt solvents.
KYHunter2
I've used it in chain saws , mowers , old farmall tractors, and of course for decarbing my boat as well as fuel additive.
I've yet to use it as a stabilizer, but now I will.
No need for the sta-bil, anymore.
Its like night and day, as far as the performance difference goes.
IMHO,
KYHunter
lark2004
lol Dave.......
Basicly, I am happy it works for you guys. But we can't get it here in Australia, so we can't comment either way on it.
Does anybody know if the LUCAS range of products would do a similar job? Becuase we do have that here.
roscoe
Don't know what Lucas has available.
Can you get the Mercury Power Tune, or the Yamaha Ring Free.
Pretty much the same stuff as SeaFoam from what I've read.
Or you can made your own Seafoam.
50% Naphtha
30% light oil
20% isopropyl alcohol
