Repower Options for GM 5.7
kevperro
I'm looking at a 28' boat with a 10' beam powered with a single high hour 5.7 Volvo pushing a Volvo duoprop. I have yet to be aboard but with a displacement of just under 6000lbs I'm guessing it wouldn't hurt to add a few more ft/lbs of torque across the bottom. I'm kicking around a couple of options.<br /><br />#1. GM Marine Crate Engine 5.7 (350 CID) with Vortec heads. Cost with access. $3300 plus shipping. 355 ft/lbs 3600 RPM and 295 HP 5000 RPM.<br /><br /> http://www.ebasicpower.com/engines/base/ <br /><br />#2. Jasper Performance 383 Marine Engine.<br /><br />440 ft/lbs of torque at 3500 RPM!!!! 350HP at 5000 RPM<br /><br /> http://www.jasperengines.com/performance/chevrol1.pdf <br /><br />Cost in similiar build as above (carb, intake manifold, fuel pump, flame arrestor and ignition) $4083 <br /><br />#3. This is a GM Crate Engine but one they make for the truck market. The cam looks to be perfect for marine use and I would guess needed changes would be freeze plugs, gaskets, water pump and intake manifold. Am I missing any? <br /><br /> http://www.cheapchevyparts.com/id9.html <br /><br />Part # 12497317<br /><br />This is a 383 WITH Vortec heads new from GM. These go for about $3800 new. Not as good as the Jasper even with the Vortec heads.... insteresting. The price above is without many of the accessories and parts included in examples #1 & #2. <br /> http://www.greenwoodchevy.com/engine16.htm <br /><br />I'm leaning towards the Jasper just because they have such a good reputation and it uses proven technology. Not to mention they have a serious torque monster. <br /><br />Any thoughts????
Re: Repower Options for GM 5.7
Basicly, <br />Make Sure the Crankshaft bolt pattern,+ Flywheel are the same as you have Now... You'll also want to be Sure the dipstick is on the proper side... And the manifold bolt patterns are the Same....<br /><br />Then, Maybe everything will bolt up.....<br />And Hopefully, your outdrive will take the Added Power.....<br /><br />Any of these engines will do a great job.. But I to, Really like the added stroke of the 383" motors...
kevperro
Yes.... I think if I can give Jasper the exact engine config they can make sure it will bolt right in place. With the GM crate products I might have less flexibility.<br /><br />I think the Volvo should handle the power. I'm not going to be doing hole shots all day. I'm just looking to build a reliable fuel efficient machine with power appropriate to the boat.<br /><br />Thanks for the input bondo.
