Repower question going from 4 stroke to 2 stroke
richlbc
I have a 2000 evinrude 70hp 4 stroke (suzuki)..Anyhow it seized on thanksgiving with 296 hours..I found a good deal on a 1998 evinrude 60hp 2 stroke..Would this be an easy swap or is the wireing harness or anything else diffrent that would turn this good deal into a bad with the changeover..Any and all info much apreciated..Thanks Richard
ONERCBOATER
Re: Repower question going from 4 stroke to 2 stroke
wow that seems like really low hrs :confused:
makes me leery of 4 strokes.... any idea why it seized?
Sorry I am unfamilier enough with the engines in question that i cant help, just you completely got my attention
daselbee
Yes, the wiring harness and control is different. Gauges, etc, like the tach would have to be changed.
Please check your PMs
boobie
If it's a 2000 EVINRUDE the wiring harness and controls should fit his new mtr
daselbee
Hmmm.....the motor side connectors are totally different from any Modular Wiring I have ever seen on newer OMC two strokes.
No Deutsch connectors here....they are different. Will investigate further. Thanks, Boobie for the heads-up.
May be a year model issue.
boobie
If I remember right, OMC was marketing Suzuki 4 strokes under the Evinrude name and all the controls and wiring were the same as the two strokes. But I may be wrong.
seahorse5
The Evinrude 70 4-stroke uses the same electrical harness and controls and SystemCheck gauge as other J-E engines of 1996 and newer.
The American Suzuki version of that motor has differences in controls and wiring and are not the same as J-E motors.
daselbee
I stand corrected. I have four down in the shed, and upon looking, I see that they are indeed all Suzukis, but two of them have Evinrude engine covers. None of the engines I have will accept the Modular Deutsch Systems Check style harnesses.
richlbc
Pulled sparks plugs today and got a milkshake pouring out when you turn motor over..All fluid came from lower plug..Good thing is it is turning over i guess
boobie
Are you going to try and repair this 4 stroke? Get back to us if you do.
richlbc
I would like to now since it spins freely.Anything else i should check befor tear down to know if it is worth it?
boobie
Run a compression check on it and see what you come up with.
