I have a 1979 Mercruiser with a 350 engine that is shot. I want to upgrade the motor to a new gm 350 Vortec marine engine. I bought a complete low hour 1995 350 Merc alpha engine for parts.
First my old Merc had a 12 3/4 inch flywheel with the old style coupler. I plan to use my old pre-alpha outdrive, transom mount and bell housing. I have heard the 14" flywheel on the 1995 wont fit my bell housing. However, it does fit. I bolted it up to the 1995, with the 1995 starter and it seemed to crank fine. Is there a problem with this I don't know about?
also, will the triangular coupler that came with the 1995 fit the old transom mount and outdrive?
second question: my old wiring harness to the dash has eight pins, the 1995 engine wiring harness has 10. Is there an adapter or easy way to mate these up?
3rd question: will the power steering pump hoses on the 1995 just connect up to the power steering setup on my old merc setup?
4th the new center rise exhaust manifolds have an elbow off the rise that is oval on the outlet end. My old merc exhaust Y is round. Are there parts to purchase to match these up or do I just adlib with hoses etc. ?
Ed
Ed
