Repowering question.
keverdmann
I have a 86 Grady White offshore 24' currently has one outboard engine. I am looking to put 2 on. Where can I find out what length the outdrive requiered?
david_r
Re: Repowering question.
there is a couple of ways
you can measure your old eng. from the bottom of the eng to the top of the lower unit
you can post your current eng model #s and we can look it up for you
or you can take your model #s and look here http://www.skoterskroten.com/img/arsmodellstabell.pdf
hope this helps
Silvertip
The measurement is taken from the transom bracket to the antiventilation plate. 15" = short shaft, 20" = long shaft, 25" = extra long shaft.
keverdmann
Well finding out what I have is one thing.
Being that the boat is a deep V I think the engine I have now will have a shaft that is too long because once I move it over it will be deeper in the water and will cause a lot of spray and drag.
So the question really is, how do I find out what the boat requiers for a dual setup VS a single setup.
Kev
dingbat
That boat takes 25" motors in either single or twin installations
Knightgang
You are right, you do not need as much length when you move them to the side, but the lew length will be less than 5" difference, so you compensate by mounting the engines higher on the transom.
