Re: Required HP for Boat
This is just my speculation.. <br /><br />but here is one criteria I'd use.... longevity...<br /><br />If an engine has to work hard to do normal every day work.. then it aint gonna last as long..<br /><br />If its got enough power to get you on plane and crusing at your choosen speed, with your chosen load, and its in a good ecomimical rpm range at that point, then I suspect its not underpowered.<br /><br />It should also have a good bit left over for those times when you need to get away from something quickly. (like the shore, the wife, a storm etc.)<br /><br />I rececently discovered that my kicker motor was underpowered for my boat, and I found out at the worst time, when I needed it... and I lost my canopy and favorite rod as a result.<br /><br />I'm going to get the biggest kicker I can find that doesn't add significanly to the weight...<br />because when you need it, and you don't have it, you always regret it...<br />So I am upgrading from a 6hp to a 15HP.. which as I understand it is the biggest of the "small" outboards.<br /><br />rgds<br /><br />Franki
